My wifes Android X reset while my daughter was trying to fiqure out the password to get in. Is this possible, all the data except the phone contacts are gone.
Welcome mattsmoski!
Which device do you have? The Droid X?
I suppose how you have it set up as far as what the phone will do when too many attempts at a password entry are incorrrect.
Did you eventually get the device unlocked?
I'm sorry to hear about what happened, the device may have had a security setting in place if someone stole the device and entered the wrong unlock code the device is to factory reset itself.
If this is the case unfortunately you may have to start from scratch unless contacts was backed up to your Google account or sd card or sim card (if device is gsm)
