Accessories Angled USB cable for the Atrix..
I wanted to do the research and post it here but it seems I'm going to need your help guys. :)
I think a lot of other Atrix users like me dislike how the motorola-supplied micro usb cable gets in the of your hands if want to use it while plugged.
I almost dropped it at my computer desk number of times due to this.
So I just went on to look for a cable with a 90-degree angled connector.
I know that an angled connector may block the HDMI port but not everybody are looking to use both ports at the same time.
Here's what I found..
Amazon.com: 6FT USB A To Left Angle Micro B USB Cable: Electronics
But I'm thinking this connector might be facing upward which would be just as bad at tangling with the hands. Please help at figuring out how this cable would fit and use your searching skills to find the proper cable. :)
Thanks and gold luck.
Judging from the image provided, the cord will face upward so IMO it would be worse than the stock cable in terms of tangling with hands.
If you blow up the picture, you would see that when connected to the phone, the cord would be facing downwards. As you look at the picture, the mini part is upside down.
