Help Angry Birds for Legend
c_man
Does anyone know if its supported for the Legend?
Couldn't spot it in the market , so grabbed the APK file from XDA.
It doesn't launch :eek: just goes to a blank screen and then returns to the app list.
Have tried launching 5 times, still no luck.
Reboot as also not helped.
Am running Azure CM6 ROM.
Is it not supported on the Legend? :mad:
works fine for me on my 2.1 legend (virgin stock rom)
frame rate is kinda slow sometimes but its a beta ver after all
Updated from Azure0.5 to Azure1.0 - it runs now... though not sure about the resolution - not suited for our screen size maybe? The sides are chopped off... Its frozen a few times too...
I'm on UK VF, its not in market but I got the APK. It installs and runs but I had to reboot to get it started. Seems fine, tiny bit of slow down sometimes but it doesn't affect game play.
^ same. It also wouldn't show up for me in the market. Also wouldn't grab it via the barcode/Qcode thingy.
Hence went down the AOK route, its available over on XDA if you want it...
works fine but slows down when many objects are moving. stock eclair 2.05
I have the apk, but it won't install saying I don't have enough space on internal drive - I have 35 MB left. The apk is about 12 MB I think, so wondering how much space it needs?!
Can someone with it installed let me know.
Cheers.
Cheers.
Hi,
i am from Malaysia, got my legend from Singapore about 2mths ago.
Also couldnt get the game from Market but able to download a .apk file but also was shown "not enough space".
although i hav bluetooth or save using my USB, it will never show up when i search through my phone, not even in Manage Application. so, i dint manage to install it.
can anyone help on this too? thanks a million.
Well finally got the bEta version 2 to install by freeing up 50MB of internal space.
However, the game wouldn't get past the initial loading screen - crashes out back to the home screen everytime. Boo.
