Help Angry Birds Not Supported?
stucker1224
I just started running cyanogenmod7.0.3 on my nook color and am an angry birds fanatic. I was all ready to start downloading the free angry birds and it says my device is unsupported for that item. A similar issue came about while trying to download Angry Birds Seasons, Facebook and others, (however Angry Birds Rio was the only one supported for my bnNOOKcolor) any ideas why? And any possible fixes?
The problem with older versions of CM7 was the screen dpi was set to 161, which meant some apps weren't thought to be compatible by Market. That issue was fixed with the latest stable version of CM7... 7.1 stable, which uses a dpi of 160.
Assuming CM7 is installed ON your NC (not the sdcard), you could do my Quick'n Dirty update: http://androidforums.com/nookcolor-...dirty-upgrade-your-cm7-using-rom-manager.html
O/w you can manually change that setting here: http://androidforums.com/nookcolor-all-things-root/399848-limited-market-cm7-usd.html#post3241000
