Root Angry Birds not working after Root?
I had angry birds on my phone and when I did the root I deleted everything.
Now when I try to download it it says unsuccessful.
Any ideas? I tried the new seasons one also and that doesn't work either.
Help!
Works fine for me - Beat the Beta on Root, then started over on the official download...
Clear your Market cache, reboot, and try again???
Hi did you find a work around? I have the same problem, Angry bird worked before I rooted the phone I removed it and try to re-install and now it will not even install on the phone . :confused:
I used the one-click root on a Samsung i9000 Galaxy S. Also after I rooted the phone I can no longer find the New York Times App in the app store. Before I root it is there after I can not find it.
You mean you can actually get angry birds to be not laggy? I'm running stock un rooted and my game is so sllloooowww, even from the very beginning of the boot screen
I don't know what "root" means, but my angry birds seasons won't start anymore..
I run it on a samsung galaxy. the old angry birds starts just fine, but when I start seasons the screen goes black and the phone vibrates once. when the desktop returns the phone vibrates twice.
I'd suggest you guys try the Eris Market Fix. It should bring back the NY Times app for the guy that can't find it as well. Make sure to do a nandroid backup in recovery before applying the fix. After you apply the fix, reboot into recovery, wipe dalvik and reboot. You chould find things to be better with the market. I'm not sure what Roms you are using but it has worked for many people on 2.1 and 2.2 roms. I'm not sure if it has been tested on any of the CM7 2.3 roms yet though.
