Animated screen rotation
n3fih
I feel foolish as all get-out, but I have managed to put the screen on my Eris into an animated rotation mode. I.e. instead of snapping from horizontal to vertical, it rocks from side to side for a annoying period of time. I can't find the setting under 'display' Help!
THANK YOU! I had removed the app shortly after installing it, but it appears removing the app didn't restore the setting. I reinstalled it, and cleared the setting.
i this the fancy animations that are set in the spare parts app?
Dang, and I knew the answer to this one! You're just too fast - clearly you need to spend more time working... :)
That's interesting that it's settings remain behind after the app is deleted.
Caddy, remember that, it'll come up again some day (and you'll see the post before I do).
Isn't spare parts designed to give access to features that are already on the device? I think that is the reason the settings would be left behind after an uninstall.
I believe that to be true too, however *I* have never seen that particular setting, outside of Spare Parts. So needing to reload the app to change a setting is not something that's going to occur to many folks.
