Ok, after 4 full charge and discharge cycles I can confirm i'm getting roughly 20% extra battery life compared to the htc battery. The phone also feels cooler in circumstances where the htc battery was getting quite hot.
Cheers
Can I ask you if you use the battery booster temperature application, and if so, can you confirm that the temp gauge is stuck @ 25 degrees? as mine is
Thanks for your reply, thought I was going madI use the HTC battery widget which reports the temperature and I can confirm that with 3rd party batteries it doesnt report the correct temperature. My Anker battery always reports 25c.
Going by how hot the back of the phone feels compared to the stock HTC battery, I would estimate the Anker battery doesnt get any hotter than 37/38c (it feels roughly as hot as the stock battery did at this temp at most) for me, compared to the stock HTC battery hitting a max of 46c on my sensation.
So yes the phone runs cooler with the Anker battery, but no there's no way to read the exact correct temp as far as I know.
Cheers
Just got an Anker battery for my wife's DHD, and it's the same story with the temperature widget
Has anyone got the 1900 mAh Anker battery for the Sensation & is there an improvement?
e. What else can I say!
guys i bought my new sensation few days ago , the battery is discharging after 6 hours only , i only check the time every 5-10 minutes , and immediately close the screen afterwards , this is unbearable.
can anybody confirm this will fit straight in without the need for a bigger back or different case or anything?
