Annoying Droplet Sound
alvarez13
I can't stand the stupid water droplet sound when pressing the screen. Yes I've turned it down in sound, but I want to hear something when I press an icon for feedback. Is there a good way to replace it with the stock JB sound?
you can change it in settings > sound > default notifications
i use Zedge to get my tones, so you can d/l ones you like then choose it
Appreciate the advice. To be more specific, I'm trying to change the system UI sounds (nature theme or w/e with the droplet), not so much the notifications. I'm sure this will require changes to the UI file or something.
  • Settings
  • Sounds
Under System
  • Touch Sounds (uncheck)
Hope that's what you were talking about.
Doesn't appear anyone has actually answered your original question so here is a quick guide to changing the sound that works. I followed this guide and now I have a simple click sound:
To change the sounds you need to replace the files TW_Touch.ogg and S_HW_Touch.ogg with something more to your taste.
Here are modified files that replace the 'doink' with simple click, as it was with the S2.
https://www.dropbox.com/s/qzsiry4eo02fq3d/TW_Touch.ogg
https://www.dropbox.com/s/hxi8hgxv6w...S_HW_Touch.ogg
Put them in system/media/audio/ui you need root and a root browser.
Yep, this is what I ended up doing. Thanks Zatx and everyone who helped out.
Here's the ICS file I used to do the replacement...
Just replace those 2 files using root explorer (after renaming the old files from .ogg to .bak) and restart and it worked.
ICS Effect_Tick
Use it for a week. It will screw up your bladder function. I would go press my IMDB app and it was like having urge incontinence. No 27 yo should have to buy depends =(
Cthu at screw up your bladder function. I may be one of the few who likes that minor feature.
Every once in a while I find the droplet sound SO annoying- must be when I'm having a bad day.
Other times I don't even hear it- even though it's there.
But ^ this is a first- I've ever read a post in which someone said it's one of the reason they got the phone...........weirdo. j/p :D
Being a manager for Boost Mobile, I never end up with really great phones like this.
Though we've got this phone called the Galaxy Rush that makes this droplet sound. I was so enamored. So i go buy the SII thinking it might have it but it doesn't...
I saw a demo phone for the Note II while i was out in the mall. I fell in love. Of course I didn't have that much money and I'm saving for braces. I had just decided it was okay to not have everything I want. You have to sacrifice if you really want something right?
Anyways...
Suddenly my fianc
Anyways...
Suddenly my fianc
