Annoying Icon bar!
Ferdzz
Hi I need help removing and Icon Bar that's appeared on my Galaxy Note 2. It's blue and has a little semi-circle tab that sticks out on the edge of the screen and when you touch it an icon bar appears with random icons on it. I can edit the bar and move it from one side of the screen to another but I can seem to get rid of it. It displays on the menu screens as well and not only on the home screen.
Really annoyed with it being there someone please help!!!
that just brings up the recent apps list . . . the icon bar is on my home-screen it pops up when you touch it
No, if you long press the HOME button it brings up previous appllications, if you long press the BACK arrow from the home screen it will do away with that annoying blue bar, and once it's gone you can long press again and see that it will bring it back.
You can completely disable the multi Window bar in the display settings. Uncheck the box for multi Window mode and it will never come back.
This waswonder
PhilosoRaptor, post: 5475956, member: 58536"]You can completely disable the multi Window bar in the display settings. Uncheck the box for multi Window mode and it will never come back.[/QUOTE]
This Was wonderful Help for me, My problem went away by doing this, Thanks
