Help Annoying volume alert
I get a message saying its a risk and hearling loss when turning volume up. Is there a way to turn this alert off.
Hi there
After two days the message still didn't get any love. And all it took me to find out, was less than a minute of google search.
Google Search for: Galaxy s4 sound warning when increasing volume
The very first post has an answer and successful fix, which I tasted, and can confirm, worked for me.
Quote:
" went into music settings and checkmarked the option to set all songs to the same volume. Now when I increase the volume, the warning message doesn't come up at all, and I can increase volume to the maximum if I want. Finally, I've been trying to fix this problem for ages, and I know others are experiencing this as well! Try this out and give me a shout if it works for you "
See, google is your friend :)
cheers
Hi there
cheers
ok? where is the "music setting" option? are you referring to the stock google music player?
Google Player is an optional download, stock player is the "Music Player", round blue icon with lime green music note on it. That's where you find the settings.
