Help Annoying website popup when plug into CPU
draconius
anyone know how to disable the annoying VCast website pop up when I plug my phone into the computer everytime?
Assuming you have the motorola drivers installed there should be a corrosponding icon on the taskbar when the phone is connected. Right click on the icon and you can disable the web page that's launched when the phone is connected.
Right click on the motorola icon on your computer in the bottom right next to the clock. One of the choices will be something to the effect of plug in action or something like that (I'm not at home to tel you exactly what it says). Go to that and select "do nothing"
EDIT: you beat me to it :)
