porky101 Well-Known Member May 5, 2010 #1 I am on 2.1 V3 and I just wanted to make sure, but when ever a OTA comes out for the Eris if it is a newer version I will get the OTA correct?
B Bishop Android Enthusiast May 5, 2010 #2 From what I've read and heard, if it's not the same exact thing you have on your phone, you will get the OTA.. Chances are very likely you will get it.
porky101 Well-Known Member May 5, 2010 #3 thats what I thought I heard too...just wanted to double check
D DDustiNN Android Enthusiast May 5, 2010 #4 And if you don't get it, I believe you should still be able to download the file from Verizon's website and install it to your phone manually. Again, none of this is 100% confirmed though, simply because there is no way to know yet
MOS95B Android Enthusiast May 5, 2010 #5 Coorect, no one knows for sure. but rumor has it the folks above are correct Had to respond just to say "I'm quote-worthy...."
