Another Battery thread.......
dug13
Ok ok, I love the phone. Been following this forum. I have the latest DI18 update. Use the airplane mode toggle and stop DRM after reboot. I use DCswitch to toggle 3g when i want it. All background updates, emails and syncing are turned off ( I do them manually). i bought two extra batts. and charger. Use Timeriffic to auto airplane at night then on in the am.
Yet at night in aiplane mode for about 8 hours I lose 6-7% of battery.
Question is= Is there a simple app that can tell me what is using my battery?
I know about the built in battery status but it not very detailed. What could use 6-7% while sleeping? Or is it sleeping and how do I tell?
BTW BT, WiFi 4g ect.. are all turned off. TWS is usually low 0-13%.
Thanks for your replies. I forgot to say I did use Batttery indicator pro and it seemed to drain the batt faster??? I am using BAT STAT which is a widget right now. Not sure wich one uses more but Bat Stat seems to use less (guestimating). I will try Spareparts.
BTW anybody know of or have a list of essential running services? Or at least what is safe to stop. I currently stop the media hub download mananger 2 ( wich starts back up) The DRM and sprint Hot spot and sprint TV crap.
Thanks
