Help Another charging question
dougouk
Hey guys, when you charge your captivate, do you let it drain down to 0 first, so that the phone turns off? Or can you start charging at 1 or higher? That being asked, do you have to charge your phone while it's turned off or can I use it while it's charging? Which is the best way?
Thanks in advance =)
