I've seen a few Jelly Bean issue threads but didn't want to hijack someone else's thread.
Firstly I want to thank those that created that masterpiece that is the Rooting for Dummies, despite my lack of tech ability I managed to root and install a new ROM, with no issues. After spending a total of 7 hours reading thread after thread, rooting took 2 minutes, if that!
Sorry for the long post that follows but I’m hoping someone can help with the problem I have.
I have had my SG2 for 2 years and prior to updating from ICS to JB a couple of weeks ago, did not have a single issue with it.
However, since doing the upgrade, I have had issues with force closing and apparent lack of charge in the battery.
A friend suggested factory resetting it. I did this and despite clearing my phone of everything (after syncing to Google which didn't work!) and then resetting it, I still had issues with the FC & battery.
So after factory resetting it again and then rooting it, I had hoped that my problem would be solved. So today after installing cyanogenmod and being amazed at how fancy it was, I thought that I would be safe to start setting my phone back up – I wish!
The first thing I did was to set up my emails, so after syncing my gmail and 1 hotmail account, I was happy to see that it had not switched off. However, when I started to sync my 2nd Hotmail account, it switched itself off, and when I tried to switch it back on, the battery was showing empty, despite being at 76% when I was syncing. I reconnected to the USB and the battery flashed from empty to 2/3rds full and allowed me to switch it back on. It is now happily charging, showing 72%.
I have removed everything off my SD card so basically it was like a new phone out of the box, apart from the Rooting, of course. I have also done the battery reset that is also recommended on here.
I think I have tried everything suggested on here but hopefully someone can anyone shed some light on my problem? I’ve ordered a new battery but can’t understand how this would be the problem as it was fine before the OTA update to JB.
My stats before the Root where as follows:
PDA: I9100XWLSS
PHONE: I9100XXMS2
CSC: I9100XEULS4
Build Info: Mon Apr 22 15:48:56 KST 2013-06-02
Kernel
3.0.31-1156082
dpi@DELL175#3
SMP PREEMPT Mon Apr 22 16:13:38
KST 2013
Build number
JZO54K.I9100XWLSS
PDA: I9100XWLSS
PHONE: I9100XXMS2
CSC: I9100XEULS4
Kernel
3.0.31-1156082
dpi@DELL175#3
KST 2013
Build number
JZO54K.I9100XWLSS
