Another newbe question.
Old Guy
Some how I deleted my bookmarks page. You know the one between the friend stream and the music player.
How do I get it back?
Thanks
No prob. Sounds like you just deleted the widget from your screen?
Just long press on the screen you want it to be on. You'll get a prompt. Pick widget, then find the bookmark widget and click on it.
