my first post here
i had android gingerbread on my phone and wanted the ICS . .
i downloaded the ICS update file , switched off my phone
then switched it on with (Power + vol. up) combination and chose install update from sd card
it installed and i chose 'reboot system now' .. . .but now it wont reboot and phone is like it doesnt have a battery
this is/WAS(unless you help) my first android phone and i messed it up on 2nd day , so please help considering me as a complete noob
thanks in advance
P.S
it might have happened because i unplugged its USB from comp. while it was updating , not sure though
thanks in advance
P.S
...go to "mounts & storage" and search for "mount" ,select it and leave it like that ...download a ROM from
