It's the new update then, you probably updated to 504 before, and now you're obviously at .24
New baseband and a few fixes.Any change xcept change in numbers???
Not yet no.is this the multitouch upgrade??
no..!!!I'm on. 504 - didn't realise there was an update to it.
Z3US: did the update wipe your phone?
fixes like can u name them..???New baseband and a few fixes.
when is x10 getting a 2.2 update or higher??? any news
Yes.also... am i up to date??? let me know please...
so is .504 up to date or not?
Okay, I deleted my original messaging app by mistake and after trying various methods went to SEUS. That took care of it but also upgraded it. 24; now I lost rooting of course.
Should I just wait until rooting becomes available for this? I would like to be able to use TB and get rid of some bloatware.
Thanks much.![]()
Hey Charlyee how you doing!? Just seen this a couple of posts down which might help
http://androidforums.com/x10-all-th...dated-2-0-2-0-24-9-01-2011-a.html#post2114403
aha, rosered to the rescue, I should have looked sorry about that.All done and doing very well now that everything works well.Hey Charlyee how you doing!? Just seen this a couple of posts down which might help
http://androidforums.com/x10-all-things-root/254097-new-rooting-method-2-1-updated-2-0-2-0-24-9-01-2011-a.html#post2114403
Thank you very much MrWomble, this will come in useful the next time I get delete happy.also, if you reroot and find you delete something from the original system - try this link for the original apps
2.1 System Apps/Framwork | 2.0.2.A.0.24 | - In Case You've Deleted Them... - xda-developers
wanted Track ID for some music that was on CSI:NY last night, found it in there
Hi guys, sorry but can you help me with this?
I'm on .504 and have rooted using Z4 root. I have Titanium Backup. To get .24 do I need to to reset my phone back to factory, update to .24 then use one of the methods above to root again?
Thanks guys,
Rooting doesn't affect the ability to use SEUS so no need to unroot.You will have to unroot and update, then to re-root you will have to use the above methods since Z4 won't work anymore
Hello guyz i just got updated my phone again and i can't find what has been updated.I already updated it before to 2.1.And now when when i connected my phn to my laptop pc comp. showed another update...and i don't know what is in that update..
Anyone else got that...???
