never install system updates when rooted!!so installing this update would be a no no?
Here's the new update. I'm posting this at Schr9091's request.
Here ya go bro.
0a92569ef3d4.update_SPH-M820_FA19_to_FE16.zip
So this is verified to be safe? Is it Odin or CWM? What exactly does this update do? Sorry for the questions, but like other people, I was shocked to wake up and see the System Update message.
But what I dont get is what the hell is this update? I already did the FE16 update last week. This is just a 7.4mb system update. Is someone (Kouma Im looking in your general direction,that's the official update.zip. don't bother trying to flash it.
you need to edit your build.prop to say you are already on FE16. ctmod3.6 says FA19. make sure you change all instances of FA19 to FE16.
also wipe cache in cwm.
search the forums for "sed" and you'll find kouma's clear instructions on how to change it and why it works.
start here and continue reading. how to get rid of system update
) going to make an updated rooted Odin version with this new update?that's the official update.zip. don't bother trying to flash it.
Thanks for clearing that up for me... I wasn't exactly sure what that one was... I was taking a shot in the dark... lol... ODIN is the only way I update... When that happens... Still on EJ06...
But what I dont get is what the hell is this update? I already did the FE16 update last week. This is just a 7.4mb system update. Is someone (Kouma Im looking in your general direction,) going to make an updated rooted Odin version with this new update?
kouma has already made the updated version. 7.4mb is the size of the fa19 to fe16 update. it's in either /cache or /data/cache in your file explorer. delete it, make sure you have edited your build.prop correctly and the update notice will go away after reboot.
edit: did the update download to your cache again? how did you edit the build.prop? (meaning did you use the sed command or use a text editor)
Guys I got a problem, I Odined the FE16 update and all kinds of things are wrong. No Wifi, Laggy, screen will not stay on..
I've Odined 3 times in the past day, since lastnight, i've tried the FA19 and EJ06
All have the same issue, wifi will connect, but it will not show my router.and will shut it the wifi off after searching..
When I tried to restore a back up in CMW it says the boot images is wrong. So I flash KK2.5 and then tried to restore, same issue..
I've tried that on all three "updates" I have no clue whats up.. I've also used two different cables and three computers. my two desktops and my laptop..
Is my prevail dying??
-J6
Try a fresh install of the ROM (or flashing one period if your still stock, lol.)
What is the whole error in cwm?
Forgot to mention that. I've tried CT and HalfAss.. I'm mobile right now but the error when restoring it just says the boot image doesn't match, but the backup is kk2.5?
Did you transfer the backup to your card from PC? Could have corrupted during the transfer...
nothing, same thing.. any other ideas? lol
Here ya go bro.
