Root ANT+ on Bionic
from what i saw the only supported device is the motoactv, i am not sure how much that will come into play for you, but it lists the compatible devices, i hope it somewhat helps
Yes I did see the list. It appears to be some type of driver/firmware update. Having read the user reviews I did not want to try this as it appears it can not be reversed. I hope one of the resident gurus may have an answer to getting ANT+ active.
