Rangerdavid
My extended battery cover has a really short (small) antenna which has created a discernable difference in my reception when I use that one instead of the OEM battery and case back. Is there any way to make this antenna longer, larger or just get better reception?
Back in the day, when we had televisions with rabbit ear antennas, we could put aluminum foil on them to get better reception. You think that would work on a cell phone?
RD
RD
