I have checked, but I haven't found any app that will do the job. I just want the volume keys to control volume for ringer, notifications, and music all together. I don't know if what I'm looking for has to be specific to the Motion 4G, or just the version of Android. Thanks!
Pedro, I know that, but I was looking for something that will change all volumes together so if I forget to lower one, I don't get blow out volumes at bad times.
For the dolby effecs/equalizer, try Music Volume EQ in the Play store. Not the exact same as the dolby setting in the built in media player, but you can tweak the sound of pretty much anything that plays audio quite a bit with it.
i use Audio Manager Pro. the volume rockers dont control ALL volumes but what you can do is create homescreen shortcuts to your volume profiles. what i do is i have one for LOUD that is all volumes loud and vibrate then i have one VIBRATE ALL where all volumes are off except for voice calls and it vibrates.
edit: they do have a free version in the market that has slightly less options. not really sure which ones because ive always used the payed version.
