Help Any Ideas...
lcfz86
Any ideas i can fully uninstall the madden 11(original game in xperia play) or i can block the game...
the game always suddenly install to my xperia play & my phone will lost internal space 10mb, if i dun do anythings... someday it will install 2nd times & lost another 10mb...
Only way is to root your phone, which will void your warranty (just an fyi)
Yes there is no way to remove it unless you root the phone, If you are not worried about the warranty then you can root it yourself in a matter of minutes, I will post a link below to an easy to use rooting guide, the one I use is called DooMLoRD v3 which took me less than a minute to root my phone with a few clicks of the mouse. And then you can delete it and much more....
[HOW-TO] Root Phones w/ Android v2.2.x-2.3.x (zergRush Method)
thx u guys for the help...
but root the phone is not help for me... couse i promise myself i will not root the phone...
Well, offhand, I'd say you have only a few other courses of action.
1. You could try doing a factory reset, which will wipe out everything and put it back like it was from the factory.
2. You could call your cellphone provider and see what they can do to help you.
3. There is no 3rd option that I can think off, other than the 'R' word you have promised yourself not to consider.
(Rooted mine 5 minutes after I unboxed it and never looked back! :D )
