Android?What!?
Anyway someone can help me figure out if we could center the clock in the status bar?
Here is a clue:
https://github.com/BobZhome/android...mmit/525ed40eb0508a50542f451ca9ba8ea853d5e87e
https://github.com/BobZhome/android_frameworks_base/commit/b129a155c4d86fc6588123fb2a4ce20223ca32d5
A friend of mine(JerryScript) wrote code to build it into his CM7 ROM.
AYou may need a tool called smali ,i never used it so i am not sure.But you can do allot with this. I think the line with fffooo. I think thats color. So you can change the color.
And i saw something else.
It looks like you can change your signal bars into numbers.
And the guy that wants to hide the clock needs,this.
Edit i dont think you need smali
Google how to open .ui
Find software
Copy system.ui to computer
Open system.ui
Open statusbar.xml
Modify
Put system.ui back where you got it
Reboot
I have never done this and dont know if its exact procedure.
But that should give you an idea.
If you can do that you have learned a little about building websites as well. That style of coding is how html websites are put together
thanks i have a feeling its to much for the guy,but wiil help someone sometime.
it sorta got me interested in actually doing a more visual mod for a change.
Rhino, would you know of such a distro?
