Root Any problems after installation of cyanogenmod 7?
raw9345
hey guys im thinking about installing CM7 but before i do, i would like to know if any of you have experienced any problems after installation? for example, does the WiFi, Radio,GPS and Bluetooth still work properly?
See my thread on the subject for the quirks i have. Might be a problem with GPS which is apparently fixable but all the others you mentioned work fine.
