M Mischka7 Well-Known Member Apr 29, 2010 #1 Sorry, I did try to search for this but I didn't come up with anything viable. Is it OK to use the phone while it's going through its first charge?
jbdan Extreme Android User Apr 29, 2010 #3 None here other than 1 random reboot....don't know if this was because I was charging it though.
CheezWiz Well-Known Member Apr 29, 2010 #4 If you start using the network, you can actually drain the battery, according to reports.
M Mischka7 Well-Known Member Apr 29, 2010 #5 CheezWiz said: If you start using the network, you can actually drain the battery, according to reports. Click to expand... Really? I just found this thread: http://androidforums.com/htc-incredible/69534-battery-charging-myths.html I'll read through it and see what the deal is. Thanks!
