This is so frustrating. Why can't I have my gingerbread and eat it too!!
So I take it there is no way to have a rooted device running gingerbread 2.3.4 and pandora at the same time.
This is the first I've heard of any kind of incompatibility between Gingerbread and Pandora. What problem are you having?
I can start pandora, but about 2 minutes into any song, it just stops playing. The little pandora icon still shows at the top of my screen. I can go into pandora and press pause then play and it will play another second of the song and stop.
Has anyone been able to get pandora working on rooted phone? I am running gingerbrea.d 2.3.4.
Thanks!
Which leak are you using? EP1F or EP1H?
You have two options if you use one of the above:
1) Install the new leak, EP1Q
or
2) Install this :[MOD] [EP1F] Streaming audio fix
