Help Any tips on how to enter contacts into DInc?
bearaids
I just got my new DInc and I was wondering if there is a better way to enter contact info/phone numbers. I was using a blackberry on Tmobile, and just received my DInc via the mail. Do I need to enter in all my old numbers manually? Or is there an easier way to do it?
They can do it rather quickly at your nearest verizon store but if you dont want that i know there is another way that doesnt come to me. Search these forums and you will find it.
Sync your Blackberry to Outlook using their software. Sync your Incredible with Outlook using HTC Sync.
The other option is what 4160-highvoltage said...Go to the Verizon store and have them do it, just don't let them charge you!!!
Try this How to Transfer a blackberry address book to Microsoft Windows | eHow.com
Then try to get your contacts in .CSV format and Import them to your Google Contacts. They can all be edited from there pretty easily.
EDIT: Better one (I think)
http://androidforums.com/support/1335-blackberry-contacts-g1-address-book.html#post8166
I agree with Excedio though. I think one of the best things about the Android platform is the integration with GMail. I rarely worry about editing contacts on the device. It's a lot faster to edit them in GMail's contact section and it synchronizes automagically.
