any tips?
beardy
hello ppl how u all doin? i got a wildfire and was wandering if any1s got any tips or tricks fot it? anything really. thank oo
Tips and tricks for the Wildfire will gradually build up over time, beardy.
The Tips and Tricks sub-forum is for those which are discovered and then posted there, not for asking for tips, so I moved your question to the man Wildfire area for you. ;)
As you use your Wildfire, be sure to go back into the Tips and Tricks sub-forum and post things that you think will help other new users. :)
here are some tips:
1. you should put the widgets you want, onto the front of your Wildfire
2. to move those widgets, press and hold down on a widget and move it anywhere within the UI
3. If you want to move an app to SD card, you have to go to application settings (where you move apps or remove them) press on the application you want to move and press on move to SD card (not every app allows this, but im sure there is an app where you can move every app to the card)
