Root any way A2SD Darktremor??
weirdfate
I tried running the zip on his site but it tells me the update script is bad or something like that. I think it just needs to be updated to run on the newer cwm recoverys?:smokingsomb:
i tried to use a2sd but no luck started to use link2sd which works quite well. partition card run link2sd choose ext4 reboot phone run again go to settings choose create links and bingo data etc moved to sd ext
