Help Any way i can stream to my tv using the indulge?
I have no idea. It's surprisingly hard to find a micro usb to hdmi cable.
The one I ordered did not fit. Turns out they made a typo, and the cable I received was a micro hdmi (type d) to hdmi (type a). So, needless to say, it did not fit.
As far as microUSB cables are concerned, the only ones I have found are mhl adapter ones, made for the sgs2. I have no idea how they'd work for a regular phone.
You can keep that cable if ya decide to go for the esteem... Iono if using the microUSB to HDMI to stream is a good idea, since the phone's battery life sucks, you won't be able to charge it... or will you??
Depends. If the Esteem supports MHL, than the TV will charge it.
I'm not sure at all that it does, however. In fact, I am inclined to believe the opposite :(
If u get a micro USB hdmi adapter and connect it to tv it does not do anything no screen mirroring. The induldge sucks doesnt even have zoom on camera. Shoulda got that damn huawei mercury.
