Help Any way to change sound notifications for different apps?
NJRonbo
When mail arrives, my phone alerts me with the Android whistle.
When CNN alerts are pushed to my screen....same whistle.
I want to change that. There is no option in the CNN app to change notification sound.
Is there an app or setting that allows you to assign specific alert sounds to apps that push notifications?
Thank You
Thank You
the default email app has no setting for that.
you can allways use third party apps. most of them have custom settings for changing led and sound. like k9 mail.
not sure about the cnn app have u check the app settings.
Yeah, CNN setting only has a box to check to send push notification but no choice in sound, so it uses the same sound the rest of the system is defaulted with.
Oh well. Thanks for the help everyone.
On second thought...
It can be done.
NotifierPro
You can change the default app notification sound for any application and the way it notifies you.
I thought you just wanted to change the Notification sound not change the way the notifications work altogether
My default email app has a setting for the notification sound.
-Open Mail
-Go into Settings
-Click on your email address
-Scroll down to the "Notification settings" section
-The "Select Ringtone" option lets you pick the ringtone to use
GMail App has it too:
-Open Gmail
-Go into Settings
-Click your email address
-Second option is to turn on email notifications
-Once that is selected "Ringtone & vibrate" turns on below it.
-"Ringtone & vibrate" has the Ringtone option to pick the ringtone you want.
Do I have different email programs than everyone else?
I think there is some confusion here....
I know how to change the notification sound on any given program that supports it.
Not all programs support it.
I want a different sound from each app that has push notification. This way, I can simply hear the sound and know exactly what program is sending me an alert.
In the example I used, CNN NEWS app, you can't change the notification sound. It shares the same sound that GMAIL uses. So, when an alert arrives, I can't tell the difference between the two.
I found that NOTIFIERPRO allows you to individualize the sound alerts from each app.
Yup.
Yup.
Or you could just change your Gmail notification?
No, again, that notification will only be shared by the CNN app.
The CNN app shares the same notification by default as the mail application. Changing the GMAIL application only gives the CNN application the same sound.
It's unfortunate, but some apps just share the notification sound of another. At least NOTIFYPRO allow you to individualize each app's own notification sound even if the app itself doesn't support it.
Thanks, guys!!!!!
Thanks, guys!!!!!
What he means is if you change the Gmail notification, it will be different to CNN because Gmail wont be using default.
If you want gmail to be whistle, change Gmail to whistle and default to whatever you want CNN to be
Edit wait, what? You're saying cnn used Gmail notify not default? Well that's lazy programming
He wants all apps to have their own notification sound so that when he hears it he will know what app it is from.
Hey SURoot!
I am still on my first week with this phone so, certainly, there may tweaks I am not aware of.
The CNN news app uses the default sound. You can't assign it's own notification sound.
I am really enjoying NOTIFIERPRO. It allows me to customize alert sounds and sends notification banners to the home screen for just about any program I have.
Absolutely correct.
With the S3 in my pocket, I rely on sounds to tell me exactly what is coming in.
Oh right. Yes so what I said before the edit applies. It was the "using Gmail"that threw me
I use LightFlow, it gives me diff. notification LEDs for diff. apps + allows me to choose a separate notification tone for every app :)
Was looking at lightflow. Reviews suggest it is a battery hog.
If you think otherwise, I will try it.
anyone syaing its a battery hog knows nothing about electronics
the LED light uses very little power to light up so that is not true
I've been using BeBuzz on my previous BlackBerry for years and now LightFlow and it never affected the battery
use it, it gives u the best of both worlds
notification LED for diff. apps / events and diff. sounds for every event easily configurable
I might give that a try. Thanks.
EDIT: I jumped straight in and purchased the pro version. So far so good. Is there any way to make a notification flash different coloured LEDs?
It can be done.
NotifierPro
I installed it, and it lets me give a notification sound to apps by checking them, but they are all the system default notification sound. It does not seem to have a way to specify a different sound for each app. What am I missing?
Darkflame,
You can go into menu settings where you check off all the apps you want to be notified of. Click on the app you checked and there should be SOUND SETTINGS where you can change the default sound to whatever you would like.
It is the "ringtone" I want to change? Only available in the paid version. Not that I have an issue paying the mere pittance of the price, but I ganerally like to see software actually work. Still, for the price of tea with dinner, it isn't a bad risk. I'm splurging. ;)
Yeah, I apologize. I am using Notifier Pro.
I am still rather new to Android so I am not certain of everything, but I would suspect that most programs that send out notifications allow you to go into their menu and change the sound. You might also be able to do it just from the SOUND configuration under Android's general settings.
Let me know how you make out. Very interested to see if you get it to work as you wish.
Looks like it will work. I have noticed that if I set the notification in Notifier Pro (& probably Plus), and have a notification in the object app, both sounds are played.
I'll report back after I work with this a bit.
Notifier Pro Plus (paid version, not Notifier Pro - free version) does allow you to pick any installed app and set a notification for it. If the app has it's own notification, it plays both, unless you turn off the app's notification. For apps that either have no notification, or do not allow you to change the notification tone, Notifier Pro Plus allows you to set any app with any notification you have available.
I have installed Zedge, which has TONS of free ringtones and notifications. However, it does not have some of the things that I wanted to be able to really customize the ringtones I wanted for certain people.
I have also installed Ringtone Maker. This little app allows me to take any sound file, edit it to only have the exact sounds I want, amplify it to be loud enough to be heard, and save it for access by an app or Notifier Plus Pro.
So, I have made a couple of notifications & ring tones that I really like. For example, when someone calls that is in my address book, it plays a few loud guitar riffs from a Chuck Berry tune. When my girlfriend calls, it plays the opening vocal from James Taylor's "Whenever I see your smiling face, I have to smile myself, because I love you!" When my ex-wife calls, it plays the Mission Impossible Theme. When my Doctors call, it plays a siren. My lawyer's calls are announced with the opening bars from Pink Floyd's "Money." Family calls are announced with the Pointer Sisters singing "We are family." My sms messages are announced with the whistle from the Old Spice commercial (downloaded from Zedge). Facebook messages have another whistle notification. Breaking News from CNN & USA Today are announced by a few notes from one of those "breaking news" tunes you hear on TV or the radio.
I have managed to set up all my communications so that I recognize the source without having to look at my phone, and THAT is exactly what I wanted. So, I heartily recommend Notifier Pro Plus as the path to setting a ready tone for any app, Zedge for downloading tons of ringtones and notifications, and Ringtone Maker for tweaking any sound file to fit the length and volume you want.
