Any way to fix the resetting?
go to the warp sequent-all things root folders in this forum and look for zte update tool, download the file, extract it, and open it and install it on your pc... make sure your software is installe on your pc and follow the instructions from there.
This will return device to stock thus fixing any software related issues. Mine would not update, i ran root script, tried a few more times, and it finally updated.
I also had a random reboot issue with this device before root. Found out that the battery wasn't as snug as it should have been.I put a strip of electrical tape at the bottom thus tightening and resolving the reboots.
I always keep a folded 20 in there great for a snug fit and always have a few bucks in me.
