The one thing I miss about my Razr Maxx hd is the ability to have the phone automatically go into airplane mode during the hours I sleep. Is there any way to do it without rooting? I'm on the Verizon update so rooting is out.
Blocking mode doesn't shut off radios. It just quiets notifications. Tasker is beyond my skill set and time available. Thanks anyway. I was hoping for an easier way
Save battery by shutting off wifi and network connections.OP
Please explain the "radios" needing to be turned off.
I'm using the blocking mode for everything but those on my favorite list and alarms. My phone has not gone off in the middle of the night yet.
I guess you could just power it down when you crash.
Another member suggested it, but I would really check out Tasker, we have a forum for it here: Tasker - Android Forums
As I said beyond me. AS FOR NFC tiles it's easy enough to toggle without them. I just prefer it to be automatic. I forget to do it and go to sleep at different time so I don't want an alarm to remind me. It worked on Maxx hd. Wish it could in note 3. Seems like every new android update sucks more than the last. They always restrict more than they add.
Honestly, I think there are some guides about Tasker, I am not trying to praise the application or get on your nerves for still suggesting it, but people will help you there if you don't know how to use it![]()
That app that I suggest 2 posts up can be triggered based on time. It doesn't require NFC tags.
The reason it worked on the Maxx HD is because Motorola has a built in function called "Smart Actions." That's not a standard Google software. That's Motorola's proprietary software (I know they are owned by Google, but "smart actions" is only on the Motorola phones).
Android 4.3 blocks it. There was a time other available apps from market offered this function without the need to program tasker. Now those apps only work on rooted phones.
Okay, but if your goal is to have it turn off all the sounds/notifications, that can still be accomplished.
Phone comes with that built in. It's called block mode. I'm worried about battery not noise.
Smart Profiles looks good, but 4+ users complain in the latest version that adjusting Airplane Mode doesn't work.Just ignore him. Download Smart Profiles from Google Play. It does exactly what you want (and much more) and you don't need to root the phone. I use it and it works for me. Free app too. You'll thank me after you use it for a few days! LOL
