Help any way to load a bootload in my a200.
snowwy66
Member
i had problems with gps and decided to try a different rom or even stock rom. sometimes i can get things fixed by a simple wipe.
my problems started with getting a rom to load up., had no luck what so ever. today i called acer support. they had me do a hard reset by using the lock button. but no luck. which was no biggie. as it fixed my dillema of getting the bootloader to load the customer rom back on.
everything should be golden. but nope. the rom wasn't solid. so i tried to do a different rom. only to find my bootloader was wiped.
so i tried to reinstall using the simple recovery tool everyone is using. but forgot to turn avg off. so i wasn't haveing much luck. anyways, while playing around. somewhere i wiped out the rom. so now i'm dead in the water. no rom, and no bootloader to load a rom.
is there anyways to install a bootload on a dead a200. it turns on. with the logo. but that's as far as it goes. the bootloader is still unlocked. but it's not root and installed to load another rom.
i know nothing about linux and adb so that won't do me any good.
i just bought this tablet. but i'm a long haul trucker and won't be home to exchange it for awhile. if i can get a bootloader back on. i can install another rom. and hopefully have a working tablet again. with hopefully a functioning gps.
i
i have weapon installer on sdhc. is there anyway to get the tablet booted into the sdhc to load the weapon installer so i can get a bootloader installed again?
God morning:
Tablet off.
Push button up volume + button start until vibrate.
Switch button rotate display from off / on continuos move until charge system.
Goodbay
