orion88
Syncing my Note II with Outlook 2010 (via USB cable) is a nightmare. It takes about 30-45 minutes each time (calendar, contacts, tasks, notes). It's the same if I'm using either Kies or MyPhoneExplorer.
Is there any way to speed this up? It only takes a few moments to sync iPad or iPhone with Outlook using iTunes, or about the same amount of time to sync Nokia N900 with Outlook using PC Suite.
30-45 minutes for a modern device such as Note II is just insane.
) than Kies (which is too much like iTunes).
