Anybody an Ubuntu geek and able to help me?
poopookakada
I've been away from PCs and Ubuntu for a while now and finally got my PC up and running again.
Here's my problem..... I have set up my laptop replacing pc as follows:
ASRock N68C-S UCC Motherboard
2.8Ghz AMD Athlon 2 Dual Core (64 bit)
2Gb DDR2 RAM
1Tb Hitachi HDD
LG Dual Layer DVD RW
I have installed Ubuntu 10.04 and got all the drivers up and running without any hassle..... except for one.
The onboard sound produces nothing, yet the drivers are installed and showing. All I want is to be able to connect my PC to my home stereo through the centre speaker port (the green one on the back) and for sound to actually come out ;)
Any help would be greatly appreciated guys :)
2Gb DDR2 RAM
1Tb Hitachi HDD
I am sure there are many here who can help but I'm sure you will get a much faster response that better suits your issue at ubuntuforums.com
It's where I go for all my ubuntu/Linux issues and they are amazing for this subject
yea i posted there too but, in my experience, they're often slow to respond and i can't live without my music :)
here's the results of lspci -v
Code:
00:00.0 RAM memory: nVidia Corporation MCP61 LPC Bridge (rev a1)
    Subsystem: ASRock Incorporation Device 03e2
    Flags: bus master, 66MHz, fast devsel, latency 0
    Capabilities: <access denied>
00:01.0 ISA bridge: nVidia Corporation MCP61 LPC Bridge (rev a2)
    Subsystem: ASRock Incorporation Device 03e1
    I/O ports at 0900 [size=256]
00:01.1 SMBus: nVidia Corporation MCP61 SMBus (rev a2)
    Subsystem: ASRock Incorporation Device 03eb
    Flags: 66MHz, fast devsel, IRQ 11
    I/O ports at dc00 [size=64]
    I/O ports at 0600 [size=64]
    I/O ports at 0700 [size=64]
    Kernel driver in use: nForce2_smbus
    Kernel modules: i2c-nforce2
00:01.2 RAM memory: nVidia Corporation MCP61 Memory Controller (rev a2)
00:02.0 USB Controller: nVidia Corporation MCP61 USB Controller (rev a3) (prog-if 10)
    Subsystem: ASRock Incorporation Device 03f1
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 20
    Memory at f9dff000 (32-bit, non-prefetchable) [size=4K]
    Kernel driver in use: ohci_hcd
00:02.1 USB Controller: nVidia Corporation MCP61 USB Controller (rev a3) (prog-if 20)
    Subsystem: ASRock Incorporation Device 03f2
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 21
    Memory at f9dfec00 (32-bit, non-prefetchable) [size=256]
    Kernel driver in use: ehci_hcd
00:04.0 PCI bridge: nVidia Corporation MCP61 PCI bridge (rev a1) (prog-if 01)
    Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
    I/O behind bridge: 0000e000-0000efff
    Memory behind bridge: f9e00000-f9efffff
00:05.0 Audio device: nVidia Corporation MCP61 High Definition Audio (rev a2)
    Subsystem: ASRock Incorporation Device 0397
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 22
    Memory at f9df8000 (32-bit, non-prefetchable) [size=16K]
    Kernel driver in use: HDA Intel
    Kernel modules: snd-hda-intel
00:06.0 IDE interface: nVidia Corporation MCP61 IDE (rev a2) (prog-if 8a [Master SecP PriP])
    Subsystem: ASRock Incorporation Device 03ec
    [virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=8]
    [virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=1]
    [virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=8]
    [virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=1]
    I/O ports at ffa0 [size=16]
    Kernel driver in use: pata_amd
    Kernel modules: pata_amd
00:07.0 Bridge: nVidia Corporation MCP61 Ethernet (rev a2)
    Subsystem: ASRock Incorporation Device 03ef
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 27
    Memory at f9dfd000 (32-bit, non-prefetchable) [size=4K]
    I/O ports at d480 [size=8]
    Kernel driver in use: forcedeth
    Kernel modules: forcedeth
00:08.0 IDE interface: nVidia Corporation MCP61 SATA Controller (rev a2) (prog-if 85 [Master SecO PriO])
    Subsystem: ASRock Incorporation Device 03f6
    Flags: bus master, 66MHz, fast devsel, latency 0, IRQ 23
    I/O ports at d400 [size=8]
    I/O ports at d080 [size=4]
    I/O ports at d000 [size=8]
    I/O ports at cc00 [size=4]
    I/O ports at c880 [size=16]
    Memory at f9dfc000 (32-bit, non-prefetchable) [size=4K]
    Kernel driver in use: sata_nv
    Kernel modules: sata_nv
00:08.1 IDE interface: nVidia Corporation MCP61 SATA Controller (rev a2) (prog-if 85 [Master SecO PriO])
    I/O ports at c800 [size=8]
    I/O ports at c480 [size=4]
    I/O ports at c400 [size=8]
    I/O ports at c080 [size=4]
    I/O ports at c000 [size=16]
    Memory at f9df7000 (32-bit, non-prefetchable) [size=4K]
00:09.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
    Flags: bus master, fast devsel, latency 0
    Bus: primary=00, secondary=02, subordinate=02, sec-latency=0
    Memory behind bridge: f9f00000-fbffffff
    Prefetchable memory behind bridge: 00000000c0000000-00000000dfffffff
    Kernel driver in use: pcieport
    Kernel modules: shpchp
00:0b.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
    Bus: primary=00, secondary=03, subordinate=03, sec-latency=0
00:0c.0 PCI bridge: nVidia Corporation MCP61 PCI Express bridge (rev a2)
    Bus: primary=00, secondary=04, subordinate=04, sec-latency=0
00:18.0 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] HyperTransport Configuration
    Flags: fast devsel
00:18.1 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Address Map
    Flags: fast devsel
00:18.2 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] DRAM Controller
    Flags: fast devsel
    Kernel modules: amd64_edac_mod
00:18.3 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Miscellaneous Control
    Flags: fast devsel
00:18.4 Host bridge: Advanced Micro Devices [AMD] K10 [Opteron, Athlon64, Sempron] Link Control
    Flags: fast devsel
01:08.0 Communication controller: Agere Systems 56k WinModem (rev 01)
    Subsystem: Mac System Co Ltd Device 1005
    Flags: bus master, medium devsel, latency 0, IRQ 11
    Memory at f9effc00 (32-bit, non-prefetchable) [size=256]
    I/O ports at ec00 [size=8]
    I/O ports at e800 [size=256]
02:00.0 VGA compatible controller: nVidia Corporation NV43 [GeForce 6600] (rev a2)
    Flags: bus master, fast devsel, latency 0, IRQ 19
    Memory at fb000000 (32-bit, non-prefetchable) [size=16M]
    Memory at c0000000 (64-bit, prefetchable) [size=512M]
    Memory at fa000000 (64-bit, non-prefetchable) [size=16M]
    [virtual] Expansion ROM at f9fe0000 [disabled] [size=128K]
    Kernel driver in use: nvidia
    Kernel modules: nvidia-173, nvidia-current, nvidiafb, nouveau
that was my first thought too and after trying to solve it for several hours into the night i gave up.
I opened the alsa config file and saw that the device was set as secondary and to be ignored even though it was the only device in the system. Changed it to 0 rather than 2 and rebooted... job done :)
now all i need is dual monitors and i'm sorted :)
