Help Anybody else having voice mail problems?
VMN490
My VZ voice mail accepts my password sporadically while on my wife's phone it does not accept it at all even when calling from another line. We have worked with VZ reps and did all the easy things (like reset the password, reinstall sim card, etc.) VZ has maintained its a VZ issue until this morning when I got a message from a VZ engineer saying its a software issue. Supposedly, if the volume is too loud when you enter the password it creates some kind of feedback and does not work. An update will fix it. Before I complain some more anybody else having a problem?
open the dialer, click on the 3 dots and select "settings". Once there, select "DTMF Tones", then choose long tones. this fixed the issue for me.
Thanks for the tip. Just tried it but it did not work. I am going to try re-setting the password one more time.
I managed to get both voicemails working but only if the passwords are entered when the phone is NOT on speakerphone. Strange, but it supports what the VZ engineer told me about some sort of feedback from the phone.
Can anybody verify there VZ voicemail works if they enter their password while on speakerphone? Surprising I seem to be the only one with this problem.
If it helps at all, use Google Voice for your voicemail. I absolutely HATE having to call a number and wait through voicemails.
Since I got GV on my OG Droid, I've never use the regular voicemail. I don't understand why people just don't use GV... For me, it's just better and easier to use then Verizon's.....
