Help AnyCut Metro PCS Hidden Menu
P.S.: This is in fact going to be a USB Tether Mode available. Enabling this
option will harm you device in ANY way. In order to attemp to install the
driver properly you MUST connect to PC, enable "Internet Connection"
mode, THEN enable "LTE USB". If you enable "TLE USB" before entering
"Internet Connection" mode the computer will not even attempt to
recognize the phone. So this means if you DO enable this option, before
you can have it connect to the computer again u MUST disable the
"LTE USB" option before your computer will recognize it
I had missed this part all along.
Nothing ever became of this?
Maybe we can combine this and latest related thread....
Hopefully latest thread stirs something up....
Just locate the other thread and "report" to see if they can be combine or merged together...not sure if they can do that but worth a request:D
I would but not sure which thread you are referring to(they has been a few);)
I gotta say this, you- Gbiggie, and everyone else here are so nice.
This is the only forum like that in the entire web.
Everywhere else folks are chided for not being able to stand the heat heat.
Appreciate that:D
Check this out..they did some update today and everyone was down.with 4g for a bit..talk to Josh in CA..his setting for ipv was both 4 & 6 afterwards..mine in MI only 4...so I changed mine. Much smoother transition from 1x to 4g:thumbup:
EMbr4AS0
Appreciate that:D
EMbr4AS0
that's funny...one fairly recommended firefox speed tweak is to disable ipv6.
Gonna try your suggest, thanx!!
Appreciate that:D
EMbr4AS0
I've seen this setting. For the life of me can't find it.
Where did you access it?
Thanks.
Its AnyCut..new shortcut..APNs..Open shortut..Click on METROINTERNET..IP Version..gives you 3 options..IPV4,IPV6, or both
arrgghhh....i had already made that shortcut...the image is misleading-- looks like a toggle on/off button instead....was kinda leery of clicking it for that reason.
ty, ty, ty, ty!!!!!!!!!!!!!!!!!!:p:p:p:p:p:p
