RiceEatingEvo
I was just wondering if anyone else has had problems with the PowerMat Wireless charging dock? Of course they dont make an adapter for this phone but in the box there is a wireless Mini USB charger in which you can put tips on to match your device. well i put the Micro USB tip on and sat the USB stone on the charging pad. The phone recognised the charge and what not but what threw me off was my screen became Extreamly sensitive and responsive. but was acting wonky. For example i would tap on one part of the screen but the complete opposite side would light up. For example if I were to try to drag down the notification bar the screen would slide to another panel. If I was in the application drawer and would click on an icon the phone would select an icon that would be about two to three rows down. and the keyboard wouldnt always light up and the phone wouldnt recognise the accelerometer from me turning the phone sideways. But as soon as I unplugged the phone it went back to normal and all the functions worked like they should. So my question is what could be causing it to do this and has anyone else had this happen?
