Help Anyone else have problems w/Android Keyboard
Paleonut
Hello all! I've had my new Triumph for almost a week, and I have noticed that my Android Keyboard (which I prefer) won't substitute correct words for misspelled ones. It will highlight the word, but won't substitute it when I hit space... For example, if I type i, there will be an orange I, but when I hit space, it stays i.
I'm trying to figure out if this is a problem with my phone, or with all of them, and if there's any way to fix it.
I've also noticed that if I take a picture, when I enlarge it in the gallery, the resolution never improves (I know there's a limit, but normally if you zoom in a bit, the picture would refine).
Any help/suggestions would be greatly appreciated!
I would suggest using the ice cream sandwich keyboard. I had some problem with keyboards before i installed. Search it up on the forums
hello paleonut, I have this very cool keyboard app that I just downloaded a couple of months ago and I've been using it ever since. search for "dextr keyboard" in google play and install it.. the cool thing with it is the landscape keyboard that's specially modified for your thumbs to fit. Just try it for yourself and you'll see what I mean :)
I use swype from beta.swype.com .. it takes a little while to get use to but it is so much faster than typing, and its free
