Help Anyone else having problems with Launcher Pro after gingerbread update?
Connectz
Launcher pro pretty much is broken for me after the update. Nothing stays on the homescreen. When I hit the power button or wake the phone, when it starts up all my widgets and apps are gone.
Anyone else having this problem?
I had the same issue but I was able to resolve using the following steps:
-Go to settings
-Once in settings click on "Applications"
-Choose the tab that says "all"
-Look for "HTC Sense" and scroll to where it says "Launch by default" make sure you click "clear defaults"
- Do this for both "HTC Sense and LauncherPro"
-Reboot your phone and it will ask you to choose your default launcher app
This SHOULD resolve the issue. If you're still having trouble, download "home switcher" and you should be able to set up the default launcher from there.
hope this helps :)
-Go to settings
hope this helps :)
If this does not work try reinstalling the Launcher. I have and use Go Launcher and I have only had one similar issue and that's what i ended up having to do. You may also need to clear out your cache / dalvic cache
