First, this should go into the rooted subforum. Second, VZW's plan is UNLIMITED. It's been often discussed as how much usage people are using on their data plan, and some have reported 5-10gig with no issues. I wouldn't worry about it. Are you using this away from home, or is it that you have no internet access at home? Just curious since I get a much faster speeds with my Wifi than I would with VZW.
