Help Anyone else's Sprint TV not working?
ImmaSlave4U
My Sprint TV app just forced an update upon opening it and ever since it has not worked. I receive an error that says: "resource fetch failed". How annoying...as a paying Sprint TV Xtra subscriber, I hope they fix this soon. Can anyone else reproduce this error?
it's another botched update by sprint and my guess is you have to call them and have them send you a signal with the proper update. Sprint struggles with ota.
Great tip, it worked for me, THANKS!
p.s. Sprint TV still sucks, but at least it's a working sucky app. :)
soooo i just fixed it..following these steps
Menu, Applications, Manage applications, All.............find sprint tv........click on it and force stop it and then clear data.
From there...
Get back to Menu...System updates...update profile.
It won't work on mine. Force close is greyed out so I can't select it. Can someone possibly post the updated apk.
From there...
Thanks! This worked on my rooted hero. I skipped the system update part and it still worked.
