Noonian Soong
Greetings.
So I have a very bizarre touchscreen problem that started in the middle of the day today.
If the phone is idle and the 'Screen Timeout' becomes active (the screen going black, that is), when I hit either the home button or the power button to bring the screen back on the touchscreen does not respond- AT ALL- other than that all physical buttons on the phone work perfectly fine.
I have to pull the battery out and power back up in order to use the phone again. I have set the screen timeout to 'Never timeout' and so I am able to use the phone for now.
If I hold the power button down and put the phone into sleep mode, it is the same problem when I bring it out of sleep (touchscreen does not respond at all).
So far I have tried:
Removing the SD card.
Factory Resetting the phone.
Updating to the latest update.
The phone is not rooted.
Has anyone seen /anything/ like this before? Is there any program that exists to push firmware to the device over USB in an attempt to completely reflash the devices firmware?
I have already ordered a new one. Should be here today sometime.
