Accessories Anyone going to try the Amzer 1800mah battery?
So I put in the Amzer 1800 battery lastnight around 9PM to charge. I unplugged at midnight, did about a half hour of playing, then went to bed.
As of right now I am at 65% battery. Considering the level of use I am putting the phone through I think that's very good.
I've been beating on it since I woke up at 6AM. Web, texts, calls, almost constantly.
So far, an excellent battery for the price.
Dennis
"I've been beating on it since I woke up at 6AM"
AHHHHHHHH HAHAHAHAHAHAHAHAHAHAHAHA
Dennis
You said this battery is slightly bigger - does the incredibles door still sit flush with the device, is it raised in any manner?
Thanks for the feedback! What is your current awake time and how many minutes of calls?
I don't do lots of actual calling, but I use a great deal of data and messaging. Almost constantly. So far the 1800 is lasting me till just about the end of my work day. This, based on my useage, is pretty good.
Thanks again for your answer! Do you do most of your data through WiFi or 3g? I'm using the Seidio 1750 right now but just wondering if this would be any better.
any other people with this battery want to share their experience? i want a battery that doesn't require a new cover and was about to get the seido but there has been alot of bad press the past few days, i would say about equal posative and negative for it, so the more i hear about this battery as an alternative from people who took the risk i would appreciate it. i am really only looking for a 25-35% increase in battery to get me that extra oomph.
Does the battery make the battery door slightly pushed out? What I mean to say does the battery allow the door to close all the way without any openings and does the battery push on the door with force? Is it a little thicker than the origional battery?
It fits like the standard battery... no change
