Anyone have this problem where launcher pro locks up?
When I press and hold on a widget to move it and let go of it in the place where it originally was, launcher pro locks up and I cant move through any screens.
The only way I can fix my problem is to press the menu button, go to applications and force close launcher pro.
It's really annoying, anyone else dealing with this or have a fix?
If you don't have Launcher Pro Plus, when you long press a widget and drop it in the same place, you should get an orange box around the widget, which allows you to re-size the widget. Since the re-sizing feature is only available in plus, when you press the back button, Launcher Pro will prompt you to purchase a plus license. Just decline and everything should be back to normal.
Hope this helps.
Only lock up I had with launcher pro was when I was receiving an incoming phone call. The phone would vibrate and, with much lag, begin to ring but the screen would stay off, leading to a missed call. Switching to a different launcher got rid of that problem.
