Root Anyone having problems with Marketplace?
ska.t73
Android Expert
Don't know if this is a ROM issue or what? I don't think it is as it just started a few seconds ago. I was trying to download an update from the Marketplace and it started and then a few seconds into it, I get a failed message. So I tried just a random app and I get the same thing... I saw a thread about it over on the Eris forums but was just wondering if anyone here is experiencing this?
For one update, yes, Titanium Backup update will not download.
But I tried another app (bluetooth file transfer) and that downloaded and installed fine.
So intermittent for me...so far. I'm on Cyanogenmod 5.0.5.4.
I happens to me all the time (not as frequent the past month). try again later and all should be well. With my luck it usually happens when I change a ROM or mess with settings (driving me crazy trying to correct it) and later I find out it is a market issue.
I am having this problem as well,
i have 8 updates to install,
none of them will update, i get update failed for each one, each time
