Root Anyone know how to activate on screen buttons?
Duke 505
Member
I know there is a trick you can do to activate the on screen buttons on any rooted ics device by editing a file in the build.prop. But for some reason i can't find it. It's called
"qemu.hw.mainkeys=0"
Thanks i will try that. Kinda figured that. Idk why the instructions i saw said you had to find the file lol
Also if you want to disable hardware keys then navigate to system/usr/keylayout and find syna-touchscreen.kl and open it as a text file and put # in front of every word "key" you see. Ex: #key
That file doesn't exist I just checked
If this pic shows corrupted then open it on a web browser from your phone. That shows the location of the file.
