Anyone Notice if you shutdown and Turn on Your phone again You Get Fresh Perfomance on the Data Side
EVOGUY88
Member
Never noticed until i looked at my phone awake time and it has like 1,088 hours of being on. So i decided to shutdown and Turn it on again for the hell of it i noticed my 3G Data worked like Lightning like the day i got it. My Phone of course is a ZTE WARP on Boost Mobile Unlimited Everything Monthly.
You Probably already knew this good tip to shutdown your phone and Turn it back on everyday.
Sometimes my web just get's stuck. I have Fast Reboot. It does not do the trick. I have to actually power off and on my phone the all is fine. It does not happen to often for warranty service. Heck, with these phones and their quirks, if you sent it in for ever glitch, you might as well throw it away.
when you turn you phone back on you force it to reconnect to the towers getting a fresh signal
theres alos a app i use when my 3g drops to 1x does the same thing turning on your phone does its called fresh network
Just put it in airplane mode then turn it off, does the same thing
looks like you guys always keep the 3g on all the time?I this is stupid if u don't need the data connection at some time,am I correct?:D
uhh.. why would you shut it off? who in this day and age isn't using their data connection at some point, for account syncing or whatever?
I've almost tripled my battery life by leaving 3g off when not using it... it only takes half a second to turn it off and on when necessary with the power control widget
Sent from my N860 using Tapatalk 2 Beta-5
I was exaggerating but you get the big picture
So the Anal retentiveness in me needed to time myself and it took me 4 sec on 5 different attempts not bad at all:proud:
I very rarely use it on a daily,I have WiFi at Work,Home.Gym,Family and Friends,and plenty of hot spots around at the grocery store, library,mall. Book store pretty much every where i am.I will find my self at times in the car using it with my TuneIn Radio app.or Slacker,and BeyondPod but then im plugged in to the charger.To me its just a battery hog and i switch it on and off thru the Notification bar with the app called notification toggle.I auto load my favorites sites thru GOOGLE Currents and there ready for me in the morning with no internet required and i also just started using Pocket
The best way to save and view articles, videos and more. When you find something on the web that you want to view later, put it in Pocket. It automatically syncs to your phone, tablet or computer so you can view it any time, even without an internet connection.I Love the two.
my 3g is always on due to wifi in my device is sooooo slow so i keep it on, on the other hand if i want a refresh signal i just udate prl and profile an thats it fresh new signal is my phone no need to turn it off.
